z-wave polling issue
interruptvector
Post by interruptvector »
Having a small issue here -- wondering if anyone else has bumped in to this problem. When I first boot housebot, it polls and updates the status of the lights properly (my polling is set to 10 seconds). It continues to poll properly for a while, but after housebot is running for a few minutes, it no longer polls the lights properly, and therefore there status is never updated if the light is turned off or on from the switch as opposed to a software remote or housebot.
When this problem occurs, I have tried to get the status manually and this also fails. It isn't fixed until I reboot housebot. (Running v2.22).
Any ideas or comments?
Wes
interruptvector
interesting...
I seem to have narrowed down this problem. I am using Girder to manipulate a few properties of one of the devices (not any of the z-wave stuff). Girder updates these fields on a regular timed interval. If I disable this update process in Girder, the problem seems to go away.
Can girder interfere with housebot's polling somehow??
interruptvector
still having the problem
Actually the problem still occurs even with my Girder stuff disabled. So I'm back where I started. :?
A data trace may give you some more clues. To generate a trace file:
  1. Select the Hardware Interface from the Tree View.
  2. Click on the 'Hardware Module Type' button at the top of the Interface Property list.
  3. Click on the 'Enabled' checkbox to turn on tracing.
  4. Let it begin to poll as normal and let it run. This should generate data in the log file.
  5. After it has stopped responding to polls, turn the tracing off by clearing the 'Enabled' checkbox set previously.
  6. The trace file can be found in the HouseBot\Logs directory. Look to see if it stops polling, or responding.
interruptvector
Thanks for the suggestion.
It appears that when I first start housebot, everything is fine. Below is an example of the output I get. I see polling occuring as would be expected. After about 15 mins or so, it just stops polling all together. If you try to manually check by setting get state to yes, it gets stuck at yes (i.e. the device isn't even polled, and get state doesn't get reset back to no).
Any other ideas?
Wes
portion of log file:
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 3]."
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Transmit Result]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 03 03 20 03 00]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 03]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:14PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=3], Level=[0]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [1]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 01 02 20 02 05 03]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Status = [1] - Received 0 bytes Data"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 1]."
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Transmit Result]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 01 03 20 03 63]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 01]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=1], Level=[99]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [3]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 03 02 20 02 05 03]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 3]."
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 03 03 20 03 00]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 03]"
Dec 18 2005,10:20:16PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=3], Level=[0]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [4]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 04 02 20 02 05 03]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"--> Status = [1] - Received 0 bytes Data"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 4]."
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Transmit Result]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 04 03 20 03 00]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 04]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:21PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=4], Level=[0]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [1]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 01 02 20 02 05 03]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Status = [1] - Received 0 bytes Data"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 1]."
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Transmit Result]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 01 03 20 03 63]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 01]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=1], Level=[99]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [3]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 03 02 20 02 05 03]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 3]."
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 03 03 20 03 00]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 03]"
Dec 18 2005,10:20:24PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=3], Level=[0]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [4]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 04 02 20 02 05 03]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"--> Status = [1] - Received 0 bytes Data"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 4]."
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Transmit Result]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 04 03 20 03 00]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 04]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:29PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=4], Level=[0]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [1]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 01 02 20 02 05 03]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Status = [1] - Received 0 bytes Data"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Transmit OK [Node ID = 1]."
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Transmit Result]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 01 03 20 03 63]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 01]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=1], Level=[99]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"Sending data [20 02] to Z-Wave Node ID [3]"
Dec 18 2005,10:20:32PM,Homepro RF USB Z-wave,Debug,"--> Transmitting data [09 00 13 03 02 20 02 05 03]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"--> Status = [1] - Received 0 bytes Data"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"ACK Received"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 4 bytes Data [04 01 13 01]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"Status Frame Received"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"Response frame Received. Putting data in receive buffer."
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"+++ Looking for 1, 19 (0x13), buffer contains 1, 19"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"Received Response"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 9 bytes Data [09 00 04 00 03 03 20 03 00]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"Request frame Received. Putting data in command queue."
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [09 00 04 00 03]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"Sending Subscription Notification for list [Z-Wave Reception]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"--> Sending Subscription Notification. Filter=[Node=3], Level=[0]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"--> Status = [0] - Received 5 bytes Data [05 00 13 03 00]"
Dec 18 2005,10:20:33PM,Homepro RF USB Z-wave,Debug,"+++ Dispatching Event data [05 00 13 03 00]"
