Zwave, more than one device in a task is slow
Posted: Sun Feb 05, 2006 4:58 am
by wetwired
When I try to put more than one device in a task, like when turning on a room with four lights. The delay is very long before the task is completeted.
Tasks with only one device is almost instantly completed.
Is this a problem with the zwave USB controller or Housebot? Or is there a better way to turn off many lights at once in houebot?
Any help is appreciated, thanks.
Posted: Sun Feb 05, 2006 9:31 pm
Shouldn't be a problem. I set the dim level on three different Z-Wave switches in a single Task and it all happens very quickly. There isn't a perceptible difference in the switching of each lamp.
If you have one lamp that is far away I'd add it last in the list. If the Z-Wave network has to retry or take a long route to turn the switch on, it may take longer for the transaction to complete (this is just a guess).
Posted: Mon Feb 06, 2006 4:05 pm
by wetwired
I´ll try that, thanks.
By the way, is there a way to send group on/off and all on/off via the USB interface?
Posted: Mon Feb 06, 2006 8:19 pm
wetwired wrote:By the way, is there a way to send group on/off and all on/off via the USB interface?
Nope. For myself, controlling the individual devices happens so fast that I haven't had a need for grouping commands.
same here..
Posted: Wed Feb 08, 2006 9:48 pm
by interruptvector
My experience is the same as Scottbot... I find the response time very fast for turning lights on or off.. Even with many devices in a room, etc.
My only problem remains the USB interface itself hanging after an hour or two.. I had to setup an automatic script to restart housebot every hour so that the USB interface gets reinitialized!
Not ideal, but it works! :)
Posted: Fri Feb 10, 2006 10:40 am
by wetwired
Ok, so I redid the the whole zwave installation. I reset every unit and did a factory reset on the remote. Deleted everything in housebot and cleared the USB controller. Now I have every device in group one and so far everything seems to work a lot better.
Fingers crossed.
