File not found[/CheckVersion.asp?pcode=22&sver=2.30]
Posted: Fri May 05, 2006 7:50 am
The above error shows now and then. No clou why?
I installed HB 2.30 in the original Meedio HouseBot directory and ran the upgarde.exe
Posted: Fri May 05, 2006 10:49 am
by kilowatt
I saw the same error yesterday. I suspect it has to do with automatic software update checking. I get the same error if I select 'Check for software updates' in the help menu.
Posted: Fri May 05, 2006 11:36 am
Yep, same here when checking for new software. I never actually did that since it is flagged as auto check in the Program Options. The error occured right after start up, so that must be it. Nice knowing what it causes... Thnx
Posted: Fri May 05, 2006 11:53 am
It was a web server/DB problem. It's fixed now.
Posted: Fri May 05, 2006 11:58 am
Be carefull Scott with fixing stuff so rapidly. We could get used to that;)
