Loop Routine
Pedromlo
Loop Routine
Post by Pedromlo »
The security controller HAI, is a slave device.
I need to send the request string (HEX) every second, so i can read the security zones changes and then execute some tasks.
Can you give me a clue on how to do that?
Also i want to connect a Modbus device which also needs to be read periodicaly.
bjlamarca
Post by bjlamarca »
To give you a start: Create a task that has a conditon that runs when the "System Time.Time is Not Equal to 12:00am." This task will fire every second (except 12:00:00). Then setup the serial device to send the hex data
Marchi
Re: Loop Routine
Post by Marchi »
Hello
This is my first post in CeBotics. I want to address Modbus serial HVAC and Diesel Generators using CeBotics.
From my limited knowedge of Modbus, this requires that I send a message to the devices and read the responses.
My question is: Has anyone already done this?
If so, I would greatly appreciate your input in setting this up.
Regards
