Need help on CM12U (UK Version) , some error....
Posted: Sun Nov 19, 2006 12:27 am
I'm testing HouseBot v2.32 , sometime if i try to send X10 command to CM12U , it will have following error :
[Debug] Sending X10 Command - Begin
[Debug] Sending X10 Command Part 1
[Debug] --> Read Pending... WriteData. 2 bytes
[Debug] Writing [2] bytes [04 ea]
[Debug] CSerialPort::ReadData() is requesting 1 bytes and there are only 0 bytes [] in the [Solicited] read buffer. Waited 10 seconds.
[Debug] The [Unsolicited] Buffer contains 0 bytes [].
[Debug] Error reading COM port. Error = Insufficient data in read buffer
[Debug] Due to an error, Device [Living Room B4] Property [Direct X10 Command] DID NOT change.
But the error happen ramdomly. Sometime work , sometime have error.
And I alrady use ActiveHome test the CM12U , it work , no problem and already check with the CM12U's internal clock .
Can anyone help me ?
Thank you so much.
Kevin Lo
Thank you so much.
Kevin Lo
