Thanks to bryan's interest, I have updated my weather script...this time actually parsing the xml instead of the text. I have included a .hbx file to facilitate adding it to HouseBot. Simply choose File->Import Configuration and select the .hbx file. This will create the device as well as the required properties and place the script file in the Scripts folder. The zip file also includes the .vbs file as well as a folder with weather images for creating dynamic weather images on a software remote. Additional details are given when running the .hbx file on HouseBot restart.
bryan, you will want to download this script as it fixes a bug in the CWWindChill property in the original script I sent you.
http://home.tx.rr.com/crazyrantings/Hou ... Device.zip
Yahoo Weather Feed
Nice Script
Thanks Osler. Really works well. I had run into and corrected the WindChill problem.
I wish Yahoo would add a few more days to their RSS forecast feed, but it's still cool.
- Contact:
GIFs in Software Remotes
Osler,
I noticed your script specifically addresses the .gifs for the forecasts (as opposed to bmp or png files). Is there a trick to using gifs in software remotes? My SW remote isn't liking the gif files.
Shannon McMurtrey
Sorry...finally got around to this. Find the new images here:
http://home.tx.rr.com/crazyrantings/Hou ... Images.zip
- Contact:
Thank you!
Thank you Osler for your work on the script and for taking the time to upload the images.
Very much appreciated.
Shannon
Shannon
Shannon McMurtrey
