Here's a sample config to query data from an Access database. The sample import has a database with one table, Script Device, and VB script to display the data from the table.
It's very simple in what it does, but it will hopefully be helpful as a starting point to modify to meet any specific database needs.
To use the import, just drop the HBX file onto HouseBot and restart.
Reading data from an MS Access Database
- MSAccessSample.hbx
- MS Access Database Sample Import
- (13.65 KiB) Downloaded 1162 times
This is a sample script that adds a record to the Access Database, and then modifies an existing record. Install Scott's Access import first, than copy this script to the script folder and create a script device.
- InsertUpdateDBQuery.zip
- (495 Bytes) Downloaded 1145 times
