I think I know how this works but...
I put in %1%LV.
Now how do I create a property that I can assign this command to that will allow from 000-185?
It won't seem to take a range 000-185. I changes it to 1-185.
Please don't tell me I have to key in every 000-185!
Also as a test I did put a few in. 000-050. The odd thing is that when I use this property, it shows 1-50 in the dropdown!
Generic Serial Module Property Value Substitution
Not home right now so I can't take a look at how everything is called, but there is some issue with the null character. You can set it to 255 or so to free up the zero.
Also take a look at the wildcard option * to send your serial stuff. That way you don't have to map anything. It's in the help file for the generic serial device.
