Error reading COM port. Error = Insufficient data in read b
chilliman
Post by chilliman »
Error reading COM port. Error = Insufficient data in read buffer
i keep get this error message when i try and run a task.
i am using a CM11a interface( USB ) and a X-10 lamp module and it will not turn the lamp on can any one help with is problem , i think it may be a problem with the USB connection but the system works if i use activehome software ?
thanks Chilliman
vcruz77
Post by vcruz77 »
I think the cm11 supported by housebot is the serial version not the usb version. You can use the serial one or the Powerlinc USB version from Smarthome
Saludos
Victor
vcruz77
Post by vcruz77 »
Saludos
Victor
