Indicator
Thales
Indicator
Post by Thales »
Please
I try to use a indicator button, but I have this information on log file:
Unable to find associated Command with Property and Value.
I do not understand why need I to assign any command.
I start creating a property Status on Device(CP8SR-1/2)
After I create a indicator button on Theme
I set de device to CP8SR-1/2 and Property to Status
I set the states on button to 0 to OFF or 1 to ON.
And I use the Script to SetPropertyvalue "CP8SR-1/2.Status","1"
Someone knows what am I doing wrong?
The error message you are seeing is actually coming from the Generic Serial Device. It sounds like you are trying to set a Property Value in the device, but have not associated an Interface Command to the property value.
