Insteon Time Outs
Posted: Tue Feb 26, 2008 11:19 am
I am getting a lot of Insteon timeout errors. The switches are working fine from HB. It seems that the problem is trying to get status information. I have other Insteon software that doesn't experience the problems so i'm not sure what's going on here.
For example i can be at the HB computer and my wife turns off a light somewhere else in the house. I hear the error tone and see that i got an Insteon command timed out error message. I see in the log that HB sees the light go off. Then why the error?
I am using the powerlinc v2 module. As i said, i can go immediately into say the Smarthome timer software and reliably see the status change repeatedly. I guess i am confused as to what the error is. HB sees a light go off, logs the correct info about it, and then reports that the command timed out. hmmmmm....maybe HB isn't getting the status response quickly enough. But why only in HB??? Thanks in advance..
