Winamp 5.52
Posted: Fri Feb 29, 2008 3:50 pm
by jonkjon
Is anyone using HB with the new 5.52 version of winamp? I am having issues with some extra garbage at the beginning of the playlists generated by the playlist manager. I am also not able currently to play manually created playlists either. I figured maybe its not compatible with the latest version. I am also running Vista Ultimate if that matters. Thanks in advance.
Posted: Fri Feb 29, 2008 4:28 pm
by jonkjon
I fixed the issue with the extra garbage in the playlist....(i selected the wrong playlist.) Still can't play anything though....
Posted: Fri Feb 29, 2008 6:46 pm
by jonkjon
A little more info on this: When i set the playlist from the playlist manager and then change the winamp device property "A/V Status" to playing, the device iterates through each song in the playlist and then changes the A/V Status property to stopped but winamp never actually plays any of them.
Posted: Sat Mar 01, 2008 12:35 am
by jonkjon
I solved my problem with this...i copied the wrong dll into the plugins folder of winamp.....thanks anyway
