Program close after add more command
Thales
Post by Thales »
Please I would like to know what can I do to insert more command on Interface Command Configuration.
After insert a command and try to use it on device the progrma close all the time.
If the server crashes/closes, it should create a dump file. Look in the \HouseBot\Dump directory and send me ([email protected]) the newest dump file.
Re: Program close after add more command
Thales,
I've looked through all of the dump files you have sent me. Unfortunately, none of them point to the problem. Sometimes with really nasty memory issues, the dump files are useless.
Can you export the definition (or just find the definition file in the Config\GenericSerialDefs directory) for the definition that is causing the problem and send it to me? Maybe I can reproduce it here.
