How do you delete lines in a txt file using vbscript
Posted: Mon Jul 07, 2008 2:46 pm
by James D
Hello Everyone,
I have a small problem. What is the best way to delete or remove "Blank lines" in a *.txt file using a vbscript?
Ex.
Music1
Music2
Music4
Music6
I want the *.txt file to read
Music1
Music2
Music4
Music6
I do not mind making a script device that will remove all the blanks. But I am running into some problems.
Thanks alot.
Re: How do you delete lines in a txt file using vbscript
Posted: Mon Jul 07, 2008 3:20 pm
by James D
Nevermind I found a script on the web...
Below is the attached script.
SAVElistNM = GetPropertyValue("HBdevice.HBProperty")
TotalPLNM = ("YourDir" & SAVElistNM)
'msgbox TotalPLNM 'stands for Total Play List Name ex. C:\HB_PLAYLIST\TESTLocalTest.m3u
Const ForReading = 1
Const ForWriting = 2
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile(TotalPLNM, ForReading)
Do Until objFile.AtEndOfStream
strLine = objFile.Readline
strLine = Trim(strLine)
If Len(strLine) > 0 Then
strNewContents = strNewContents & strLine & vbCrLf
Loop
objFile.Close
Set objFile = objFSO.OpenTextFile(TotalPLNM, ForWriting)
objFile.Write strNewContents
objFile.Close
