Interface Command Configuration-On Serial Device
Thales
Post by Thales »
I having a problem inserting new Command on my serial interface.
The problem is:
I do insert new commands,
But when I will try to use my DEVICE to set the command, HB closes and only allow to work with the DEVICE again after I delet the command I insert.
I saw that the problem is not with the command, but with the quantity of command or the name.
The command name is Bit20-on, Bit20-off until Bit36-on and Bit36-off.
I have today 331 command.
with 314 the was working fine.
What can I do?
Re: Interface Command Configuration-On Serial Device
If HouseBot just closes, it should create a dump file which may help find the problem. Please send me the latest .DMP file from your \HouseBot\Dump directory.
Thales
Post by Thales »
Did you received my Dump file??
Thales,
I apologize for not getting back to you sooner. I looked at the dump file, but was unable to determine the point where the crash was happening.
If you can send me the generic serial *.HDF and *.DDF files that you are using that cause the crash, I'll see if I can duplicate it here.
