I try to control HB externaly using PHP with COM object. I write:
$Obj=new COM("HBControlMod.HBControl");
$szRsp=$Obj->Connect(80, "127.0.0.1", "pwd");
It's correct?
(echo $szRsp; // "OK")
How i can call additional methods? (for example - GetPropertyValue, SetPropertyValue)
Thank!
COM in PHP
Re: COM in PHP
I've never used COM within PHP, but I would think that you should be able to just call the functions from your $Obj variable (assuming that the connect code you have works). If you look in the online help for the external control device, it will give the syntax of all of the methods available.
You may also be able to use PHP socket functions to connect directly to the external control plugin and then use the ASCII protocol.
Re: COM in PHP
Hi ScottBot,
There is a web example in ExternalComControl...what should i do to make this sample work?
Thank!
Thank!
Re: COM in PHP
Check out the "COM Control Object" section of the External Control online help. Further down the page, it explains what you need to do to run the ASP sample. If that doesn't cover it and you have more questions, just let me know.
Re: COM in PHP
I have Apache installing on my PC, i copy folder (web_sample) to web server folder (localhost) and register HBControlMod.dll. The web_sample doesn't work.
What could be the problem?
Re: COM in PHP
With IIS it should just work. For apache, you will need probably need to install mod_asp or something to get it working. I've never ran it on apache, so I can't say for sure.
Re: COM in PHP
ScottBot, Thank! With IIS web_sample work.
