Any UK users?
Posted: Thu Mar 25, 2010 6:08 pm
by itm
I'm looking for an easy-to-install HA solution and Housebot looks ideal, but I don't see alot of support for it in the UK. Are there any UK users out there who can advise on where to source the relevant hardware?
Re: Any UK users?
Posted: Fri Mar 26, 2010 5:29 am
by b_weijenberg
With the use of a RFXCOM transmitter you can control:
DomiaLite, ByeByeStandBy and most interesting, HomeEasy lamp and appliance modules, HomeEasy heater.
With the RFXCOM 433.92 receiver you can receive:
HomeEasy remotes and wall switches, Digimax, cent-a-meter, Electrisave, OWL CM113, OWL CM119, Oregon Scientific sensors and body weight scale, RFXMeter, RFXSensor.
With the RFXCOM 868.95 receiver you can receive:
Visonic PowerCode sensors and BT VP1000 sensors.
X10 is supported using a CM11.
Note: do not use HomeEasy door sensors or motion sensors. These sensors produce for about 3 to 5 seconds a RF signal with the risk of disturbance of other sensor signals due to RF collisions. It is better to use X10 MS13 or DS90 sensors instead.
Re: Any UK users?
Posted: Fri Mar 26, 2010 5:44 pm
by itm
Thanks for the info. Could I ask a few really dumb noob questions?
1. If I wanted a really basic setup, allowing me to turn on an appliance using Housebot software, would the following hardware alone let me do this? -
- RFXCOM 433.92 Transmitter (USB)
- HomeEasy Remote Control Socket (e.g. HE302S)
2. What would an RFXCOM Receiver allow me to do? i.e. what are typical examples of the functionality which I could achieve if I was able to receive signals from remotes, wall switches, sensors, etc? I can see the purpose of controlling switches directly with a remote, but how would the RFXCOM Receiver enhance this?
3. What are the advantages of RFXCOM over ZWave?
Re: Any UK users?
Posted: Sat Mar 27, 2010 6:40 am
by b_weijenberg
Yes, with the 80005 USB transmitter and HouseBot you can control the HE302S (and all other HE types and other brands)
When you switch the lights using: HE switch ==> HouseBot ==> HE module, the status is known in HouseBot and this can be used in conditions.
For example: if the switch is pressed during daylight time switch only HE module X and during nighttime switch HE module X and Y.
Or another example: If module X is On (known in HouseBot because it has received the wall switch and switched the HE module On) and motion is detected switch module Y On.
Z-Wave is a little bit more reliable, (99.9% versus HomeEasy 99.7% when using also the RFXCOM receiver with CSMA-CA)
Check the price of HomeEasy and compare this with Z-Wave,
The RFXCOM transmitter can control different brands and hardware, see the list at
http://www.rfxcom.com/transmitters.htm#80005
The RFXCOM receiver can receive a lot of different (cheap) sensors, see the list at
http://www.rfxcom.com/receivers.htm#80002
Re: Any UK users?
Posted: Thu Oct 07, 2010 6:22 pm
by itm
I've now ordered a HomeEasy appliance module pack (HE330S), and have decided to go for the RFXCom 433.92MHz transmitter with LAN interface. If I want to use this with Housebot will I need to purchase any additional interface hardware or software to get the RFXCom transmitter to work with Housebot?
