Hi all,
I have a very big problem with housebot and WHS, every time I try to start housebot I get an error "Runtime Error! this application has requested the runtime to terminate it in an unusual way" .Problem started when I have registered housebot with the key. Please advice me .
Best Regards
Housebot want start in WHS
- HouseBot Special Member
- Contact:
Re: Housebot want start in WHS
Is this a new installation?
If so, check the security settings. i think that HB requires administrator rights.
You may want to try the original database to see if it loads. Backup your HBdata file in the config folder, and copy the original HBData from the config\backup folder.
If you use plugins that are not supplied with HB, remove them before loading HB.
Also, the event viewer and the dump file can give a hint.
Thanks for reply,yaccri wrote:Is this a new installation?
Yes it was a new installation, I'm trying to install sonos plugin by Osler in a new installation.
HB is installed under Administrator rights.
I suspect that is a registration key problem. When i try to close HB it remain locked as process and I have to kill it with task manager.
Now I have new installation and will try to install sonos plugin again . I will let You know.
