VB Script & GetPropertyValue
Posted: Mon May 10, 2010 6:02 pm
by robobbi
Hello,
I need your help for the following issue.
I tried to use a generic unique vb script triggered by the "On" status change for some "X10 Transmitter" devices, according to the GetPropertyValue feature "the Device Name can be omitted if the Property specified belongs to the Script Device that is running the currently executing script".
But using eg. the function GetPropertyValue(".Power State") the code/value returned is "* error *" (Unable to find Device with Description [* error *]) :( .
Is it due to my misunderstanding? :?
Any kind of suggestion would be very appreciated.
Thanks a lot.
Re: VB Script & GetPropertyValue
Posted: Tue May 11, 2010 12:37 pm
Is your script running as part of an actual 'Script' Device, or are you executing it from a Task? This feature will only work when being executed as part of a script Device.
Posted: Tue May 11, 2010 6:30 pm
by robobbi
Thanks, that's quite clear now and I confirm the script was activated by a task :? .
Anyway, just Implemented a workaround: created a generic script device with a custom "DeviceName" property (alpha type) valued by the dedicated task (triggered on change of the "Power State" property's of the X10 device managed by the RFXCOM interface) before setting the "State" property up to "Running" for executing the generic original vb script. The generic vb script simply reads (GetPropertyValue) the ".DeviceName" and uses it to access all the properties of the interested trasmitting X10 device (eg. P8.property_name).
it seems to work ... but not really confident on its reliability in case of concurrent triggerings on more X10 devices.
Thanks once again for support.
