Execute program problem
Posted: Tue Sep 28, 2010 12:29 am
I am trying to use the execute program plugin to launch TMT3 passing a path to a bluray folder.
The program string is c:\Program Files\ArcSoft\TotalMedia Theatre 3\MMCEDT3.exe
and the argument is S:\S4DriveE\mybls\Transporter_3\BDMV
if I run from a command line as follows
C:> "c:\Program Files\ArcSoft\TotalMedia Theatre 3\MMCEDT3.exe" S:\S4DriveE\mybls\Transporter_3\BDMV
TMT3 launches and starts the Transporter_3 movie
But when I use the above in the execute program plugin TMT3 launches but does not start the movie. The total string works out to about 95 char.
The execute program has worked for TheaterTek for years but the program string for it does not have folder names with spaces.
Since TMT3 actually starts, I am assuming the spaces are not causing a problem so am I running out of character space on the internal call i.e. the argument is being truncated and TMT3 is not receiving a complete path ??
