SWRemote.exe as a Windows Shell
Posted: Sun Oct 24, 2010 3:25 pm
roussell discusses the basics of getting swremote.exe to act as a shell application here:
http://housebot.com/forums/viewtopic.php?f=6&t=856513
An issue with this is that if you exit the swremote or it's process terminates for some reason you are left with few options to log off the RDP session. I have written two applications that work together to start swremote.exe in a simple shell and monitor for termination of the swremote.exe process. If swremote.exe is terminated you will be logged out of the current RDP session.
Set-up procedures are in the ReadMe file.
This is ideal on touchscreens without keyboards (cuwin, iphone, ipad) which are used to RDP into a HouseBot server that has been made capable of hosting multiple RDP sessions. This should increase the WAF as the swremote is started upon connection to the server. Also, I have found that termination of the swremote yielding a typical Windows desktop on a screen meant only for control purposes is very unappealing to my wife.
