X10 interface for 240V 50Hz
Posted: Mon Jul 09, 2012 12:40 am
by dbuckley
Can anyone recommend a currently available interface that is natively 240V 50Hz that actually works?
Thanks.
Re: X10 interface for 240V 50Hz
Posted: Fri Oct 12, 2012 11:29 am
by jaaasgoed
I assume any 230 Volt interface will work, like the Marmitek CM11? My line voltage is 230 Volts nominal, but sometimes can be as high as 238 volts (measured), and the interface is just fine. I believe that all 230 Volts mains equipment needs to be able to work (read: not get damaged) up to a continues mains voltage of 256 volts.
Posted: Tue Oct 16, 2012 6:09 am
by NW27
I bought a X10 signal booster from
http://jvde.us/xtb_index.htm
Here in Australia we run single phase 240V 50Hz.
Neil.
