HouseBot in a Win 10 VM, continuous msgs in unRAID
Posted: Thu Nov 03, 2016 9:33 am
by starfire
I am running HB in a Windows 10 Virtual Machine (KVM) provided by unRAID.
I've noticed that whenever HB is running my unRAID log is full of:-
ov 3 12:01:14 Tower kernel: kvm [8047]: vcpu0 kvm_set_msr_common: MSR_IA32_DEBUGCTLMSR 0x1, nop
Nov 3 12:01:14 Tower kernel: kvm [8047]: vcpu0 kvm_set_msr_common: MSR_IA32_DEBUGCTLMSR 0x1, nop
Nov 3 12:01:15 Tower kernel: kvm [8047]: vcpu0 kvm_set_msr_common: MSR_IA32_DEBUGCTLMSR 0x1, nop
When I shutdown HB the messages end.
I realise this may not be a HB issue but any ideas what HB is doing that could cause these messages?
Thanks.
Re: HouseBot in a Win 10 VM, continuous msgs in unRAID
Posted: Thu Nov 03, 2016 10:45 am
Here's a reference that says:
I've noticed similar messages starting Windows VMs, even ones that work just fine and researched this well over a year ago.
My understanding is that these errors happen because Windows is probing the CPU to see if certain instructions/registers exist so it knows what features are available.
When it probes something that is not available those unhandled wrmsr/rdmsr errors get thrown from KVM.
So in most cases these errors mean nothing.
Posted: Thu Nov 03, 2016 11:23 am
by starfire
Hi Scott,
Yes everything still works fine would just be good to get rid of these messages.
Just to reiterate, this is specifically related to HB, only when I run HB do I see these messages.
I run lots of other applications like Mezzmo, BubbleUPnP etc on this system and they all run fine with no messages - its HB that causes them.
Thanks.
Posted: Thu Nov 03, 2016 3:07 pm
I agree that HB must be doing something to cause it then. If I could find what that error message is referring to, I might be able to offer a guess. Not sure where to start.
Posted: Fri Nov 04, 2016 11:57 am
by starfire
OK no problem, just thought it was worth an ask.
I can easily live with it.
