Task delay based on device Value
martijnj
Post by martijnj »
I could not find a parametric way of a delay in an task thats executing. My blinds are controled by a set of relays. So Relay 1 triggers and than after 22 seconds relay 2 triggers. The task manages the Delay 22000ms. If I want to use percentage (from the blinds option of Google) it would be great if i could PV Sub the delay value.
Martijn.
Re: Task delay based on device Value
I think you would have to have the Task run a script that could then handle the work (trigger, Property Value query for delay, delay in script, trigger).
