Sending bytes to Serial module
martijnj
Post by martijnj »
Can sombody help me with this.
I want to send the result of the following code to a serial device (8xrelay) over the generic serial module.
outbuf0 = 3
outbuf1 = 0
outbuf2 = 0
outbuf3 = outbuf0 Xor outbuf1 Xor outbuf2
Result = outbuf0 & " " & outbuf1 & " " & outbuf2 & " " & outbuf3
SetPropertyValue "Relays.Relay Commando", Result
This works fine until the outbuf2 value reaches 11
On the serial monitor the data then is 003 001 011 009'
When the value of outbuf is 12 the data reads 003 001 001 002 014. The 12 gets split in 001 and 002.
Why is the happening with the outbuf2 and not with the outbuf3.
I hope that someone can explain this to me please.
As attachment the info of the device.
Handbuch.pdf
(360.1 KiB) Downloaded 1712 times
martijnj
Re: Sending bytes to Serial module
Post by martijnj »
'solved'
'init
Output = SendCommand (1,0,0)
'Send Command
Output = SendCommand (3,0,RelayCode)
Function SendCommand (Commandbyte, Adressbyte, Databyte)
	CheckSum = Commandbyte Xor Adressbyte Xor Databyte
	If Commandbyte = 0 Then
		SetPropertyValue "Relays.RelayHex", Commandbyte
	Else
		SetPropertyValue "Relays.Relay Commando", chr(Commandbyte)
	End IF
	If Adressbyte = 0 Then
		SetPropertyValue "Relays.RelayHex", Adressbyte
	Else
		SetPropertyValue "Relays.Relay Commando", chr(Adressbyte)
	End IF
	If Databyte = 0 Then
		SetPropertyValue "Relays.RelayHex", Databyte
	Else
		SetPropertyValue "Relays.Relay Commando", chr(Databyte)
	End IF
	If CheckSum = 0 Then
		SetPropertyValue "Relays.RelayHex", CheckSum
	Else
		SetPropertyValue "Relays.Relay Commando", chr(CheckSum)
	End IF
END Function
