Panel change button stopped working
dlmorgan999
Post by dlmorgan999 »
In my theme I have a row of small panel change buttons across the bottom. Last night I was using a software remote and pushed on one of these buttons but nothing happened. I opened the theme in the editor and checked the panel name on the button and it was set correctly.
Just to be safe I saved the theme and then reloaded it on the software remote but I still had no luck. I then went back to the editor and selected a different panel from the list and then changed it back to the desired panel and saved and reloaded it. After doing this it worked fine. Any idea how this might have happened?
If you see it again, remember to save the old theme XML so we can compare it to the new. Also, try and turn on the software remote tracing. Maybe something interesting would show up in the trace file.
The client won't change panels when a panel change button is pressed if it:
  1. Is already on that panel.
  2. Has no panel name specified.
  3. Has an invalid panel name specified.
