I've been meaning to log this for quite a while. Early on when I was getting HouseBot going I discovered that the Cancel button on the software remote screen doesn't work. The UI goes away but the remote keeps loading in the background and eventually pops up. This happens on both the X86 and CE remotes (although on the X86 you have to be *really* fast at hitting the cancel button! ).
This is mainly a problem on the slower CE remotes as if you cancel and then try to load a different remote (I create icons for each theme I use) you are then loading two instances of the software remote simultaneously (which makes the load pretty slow). This behavior exists even in the most recent builds.
