Free compiler for housebot plugins
eijckron
Post by eijckron »
I'm looking for info to compile the housebot examples with a free compiler like MingW (GCC for windows) or the freely downloadable set from Microsoft.
The free download from microsoft does not support stdafx and only offers commandline compilation.
Any tips are apreciated.
The samples and helper classes do all specify stdafx.h, but that's only to take advantage of the pre-compiled header feature. There are no MFC requirements for plugin development. The API is strictly "C".
The sample apps are built with MS C++, but don't reference any MFC to my knowledge. With a little work it should be possible to build these samples with a non-MS compiler, although I've never done this.
eijckron
Post by eijckron »
Can you export a makefile from the example project, that would be a good starting point to get things compiled with the free version of the microsoft compiler.
Sure. I've attached the exported makefile for the Device and Hardware Interface samples.
eijckron
Post by eijckron »
Thanx for the info. I've compiled the template examples with GCC for windows (MinGW). The dll's are still untested, will check them tomorrow.
Some things in de SDK that were not compatible with GCC:
* In both AddData methods in CDataPack the nLoop variable is
used outside of its scope according to the most recent C/C++ standards.
* #pragma once is not supported by GCC, replacing them with
oldfashioned include once guards with ifdef, define & endif should
work for all compilers.
