Has any one looked at useing 1-wire networks with housebot.
I have been playing around with importing xml output into housebot but it seems a bit clumsy. If there was a way to poll the 1-wire network from house bot and also control relays that would be a lot better.
Also is anyone developing UPB support for housebot?? It seems alot better that X10 and you can get it here in AUS now( we seem to be a bit slow on the uptake of DIY HA here).
Heff
1-wire and UPB
I was working on a plug-in for 1-Wire but it has not been worked on for a while, other more pressing tasks came up. I hope to get back to it in the near future but I can't promise anything.
I don't have any info on UPB (even though it seems like a good protocol).
Eric
http://www.hobby-boards.com
Eric
running 1-wire solution...
hello guys.. i am running a (complex) 1-wiresolution, an would be more then happy to se a more integrated interface/device solution on HB.
this is my set up: (works-fast-but awkward to configure)
> 1-wire ( 25 temp sensors , 2 ADconverters, 1 windvane wetherstation)
> Pointsix onesix DDE server ( this is polling the 1-wire and "publish DDE links")
> hardcoded VB application for linking DDE to HB thru external control device
Why all this? i had a running 1-wire network installed when i found housebot. to do 1-wire directly in HB would be great.
as is now, to add a 1-wire device i need to add a device in both HB and onesix and recode the vb code to link them togeter.... so the net is not expanding... but works fine..
the 1-wire is great to collect temperatures, cheap and stable..
for digital i/o i use a 96 pin advantech card PCI-1753 but would like to see a cheap solution for digital io thru the paralellport as a great complement...
>ericvic: the stuff on hobby-boards look great, i would really like to se your devices get in to HB
regs walle
regs walle
DDE to HB in VB..
Hello
this is my VB code... i am not a programmer
but it works...
any enhancements or suggestions are welcome...
Dim obj As HBControl
Private Sub Form_Initialize()
Set obj = CreateObject("HBControlMod.HBControl")
' set port , ip and password for HB external control
szRsp = obj.Connect("port", "ip", "psw")
' set up DDE link
TEMP01.LinkTopic = "OneSix|TEMP01"
TEMP01.LinkItem = "Input"
TEMP01.LinkMode = vbLinkAutomatic
WINDDIRECTION.LinkTopic = "OneSix|WINDVANE1"
WINDDIRECTION.LinkItem = "direction"
WINDDIRECTION.LinkMode = vbLinkAutomatic
WINDSPEED.LinkTopic = "OneSix|WINDVANE1"
WINDSPEED.LinkItem = "speed"
WINDSPEED.LinkMode = vbLinkAutomatic
' set values on first run
obj.SetPropertyValue "TEMP01", "Value", Format(TEMP01.Text, "0.0")
obj.SetPropertyValue "WINDSPEED", "Value", Format(WINDSPEED.Text, "00.0")
obj.SetPropertyValue "WINDDIRECTION", "Value", Format(WINDDIRECTION.Text, "000")
End Sub
' update when DDE item changes
Private Sub TEMP01_Change()
End Sub
Private Sub WINDDIRECTION_Change()
End Sub
Private Sub WINDSPEED_Change()
End Sub
Private Sub Form_Terminate()
Set obj = Nothing
End Sub
i have some problems with english vs european number formats... ( . or , )
need to build in some error handling and reset links function..
the example describes moving values from DDE to housebot. you need to set up text items on a form for each item that you want to mirror. set up devices in housbot: TEMP01.Value etc
the onesix server was on their web site as a demo version for 2 devices recently..
i am running this with 30 1-wire devices and it works.
i am really looking fwd if any want to get 1-wire in to housebot. probably not so cumbersam with the TMEX drivers. if uoy are a programmer
ride on, walle
' set up DDE link
End Sub
End Sub
End Sub
End Sub
Set obj = Nothing
End Sub
ride on, walle
1-wire adaptor
Nice to see that the code works for you heff.. however any enhancements are welcome.
"Back in the old days" i bought 2 onesix servers directly from pointsix. i have it running with both HA3 (from pointsix) and DS9097U-9 from dallas.
i do not see where to download the server any more :shock: . the version i use (2.2a) , have a demo mode where you can use 2 devices (ex DS1820) for free. this is good to use for testing and small applications.
any other hints on good 1-wire software is apreciated...
regs walle
regs walle
