Scottbot
Good morning
I have an ip controller that controls garden lights etc. It has a web interface or comes with an SDK( with DLL) which I have modified I sthere any way of getting this directly controlled by house bot?
Below is module for Dll link and below that the Modified VB6 code
Module
Option Explicit
Declare Function Initreceivep6 Lib "socket.dll" Alias "receivep6" () As Long
Declare Function Datareceive Lib "socket.dll" Alias "receive" () As Long
Declare Function Datatransfer Lib "socket.dll" Alias "transfer" (ByVal variable As Long) As Long
Declare Function Datatransferp5 Lib "socket.dll" Alias "transferp5" (ByVal variable As Long) As Long
Declare Function Setdata Lib "socket.dll" Alias "setdata" (ByVal variable As Long) As Long
Declare Function Cleandata Lib "socket.dll" Alias "cleandata" (ByVal variable As Long) As Long
Declare Sub Setip Lib "socket.dll" Alias "setip" (ByVal variable As String)
VB6 code
Option Explicit
Dim wr_iostatus
Private Sub Delay(Optional ByVal HowLong As Single)
Dim OldTime As Single, Continue As Single
OldTime = Timer
Do While Continue < HowLong
Continue = Timer - OldTime
Loop
End Sub
Private Sub Command2_Click()
Dim J
J = Datatransfer(wr_iostatus)
Form1.Text1 = "io control setting val : " & J
End Sub
Private Sub Command3_Click()
Setip (Text2.Text)
Call Form_Load
End Sub
Private Sub Command10_Click()
Command10.Visible = False
Command18.Visible = True
wr_iostatus = Setdata(&H40)
End Sub
Private Sub Command11_Click()
Command11.Visible = False
Command19.Visible = True
wr_iostatus = Setdata(&H80)
End Sub
Private Sub Command18_Click()
Command10.Visible = True
Command18.Visible = False
wr_iostatus = Cleandata(&HBF)
End Sub
Private Sub Command19_Click()
Command11.Visible = True
Command19.Visible = False
wr_iostatus = Cleandata(&H7F)
End Sub
Private Sub Form_Load()
Dim P6
Timer2.Enabled = True
P6 = Initreceivep6
If (P6 And &H40) Then
Setdata (&H40)
Else
Cleandata (&HBF)
If (P6 And &H80) Then
Setdata (&H80)
Else
Cleandata (&H7F)
End Sub
Private Sub Timer2_Timer()
Label6.Caption = Date & Time
End Sub
Regards PT
IP Control of lights
Regards
PT
PT
I have revisited this issue and have 2 more questions for you.I have managed to trim the VB code and now have a small window( with buttons etc) which I am controlling with girder and using housebot to send internet events. I have a task with a dynamic image which changes when the item is on /off. However this is blind communication as per infrared.
I will be looking at using VBscript to use with the script device. When the .dll is queried it provides response say "&H40" this is related to a switch being say on.Return value of &H80 being off.( for a given switch)
If I can get the VBscript to work, how can I get the return value into Housebot?
Secondly I also have a sdk for C++. Could this be used with housebot device sdk and more importantly how hard is it to compile. Do you need C++
Thanks in advance for help/suggestions
Regards
PT
PT
Within the VBScript Device, you can either execute a Task or set a Property Value. So, for example, when you receive "&H80" you can call the SetPropertyValue() command from the VB Script. You pass it the Device, Property, and new value. You may need to create a new Device from a NULL Device and add properties to construct the Device with the properties you need.PT wrote:If I can get the VBscript to work, how can I get the return value into Housebot?
I can't say for sure, since I haven't seen the SDK, but if they are providing one, I'm assuming it should be possible. However, you do need to know a bit about C++ to be able to wire it all together. And "yes", you will need a C++ compiler and linker to build the plugin.Secondly I also have a sdk for C++. Could this be used with housebot device sdk and more importantly how hard is it to compile. Do you need C++
Thanks for the reply.
The C++ sdk in fact uses pretty much the same arguments as the VB and indeed the same dll.
I need to see how the vbscript communicates with the dll first.
In my vb.exe it is a moudle wihich parses the info from the dll.
I am pretty new to the vb stuff so I am just feeling my way around the various flavours.
Any help/pointers much appreciated.
Regards
PT
PT
I have looked at this further and it would seem I need to have an activeXdll for vb script to work(No idea how to do this yet). I believe I will then be able to communicate with the dll I have from vb script.
However in my playing and reserch I now have a vb program which accepts internet events( as per girder) so I can code up (one way) direct access to my controller in one vb program.
I guess i could also link back status(actual not just instruction) with external com control.
I will aslo be buying C++ in the next few days to look at making the device.
Regards
PT
PT
