I have seen Oslers posts about the Web browser and figured I already had my browser script posted a long time ago. I guess I didn't because I can't find it in the scripts section.
So here it is. A theme control example, the HB setup and a screenshot. At least it will give some ideas bout how to get a browser going from vbscript.
Obviously I could create an export, but it seems Osler is doing a great job already.
Web browser from vbscript
- Theme Control example.JPG (132.57 KiB) Viewed 1607 times
- setup.JPG (107.65 KiB) Viewed 1607 times
- Browser.jpg (156.42 KiB) Viewed 1610 times
Last edited by Richard Naninck on Thu Jan 25, 2007 6:32 pm, edited 2 times in total.
The script
For some reason the script didn't attach to the above posting. Here it is.
'Internet Browser
Option Explicit
On Error Resume Next
Dim Action
Dim Status
Dim objIE
Dim FavCount_1
Dim FavCount_2
Dim FavCount_3
Dim FavCount_4
Dim FavCount_5
Dim FavCount_6
Dim FavCount_7
Dim arrFavourites_1
Dim arrFavourites_2
Dim arrFavourites_3
Dim arrFavourites_4
Dim arrFavourites_5
Dim arrFavourites_6
Dim arrFavourites_7
arrFavourites_1 = Array ("Cebotics.png", "http://www.cebotics.com/phpbb2/index.php", _
"Meedio.png", "http://www.meedio.com/forum/newposts.php", _
"MeediOS.png", "http://www.meedios.com/forum/", _
"Cocoontech.png", "http://www.cocoontech.com/index.php?", _
"Elk_M1.png", "http://m1dealer.elkproducts.com/index.php?&MMN_position=1:1", _
"Automation.png", "http://www.domoticalinks.nl/")
arrFavourites_2 = Array ("BMW.png", "http://www.bmw.nl/nl/nl/index_narrowband.html?content=http://www.bmw.nl/nl/nl/usedvehicles/overview.html", _
"BMW.png", "http://www.m5board.com/vbulletin/", _
"Stinger.png", "http://www.stinger.com/index.php?lang=ne&sec=download", _
"Mobile.png", "http://mobile.de/")
arrFavourites_3 = Array ("FlashWeather.png", "http://weather.eu.msn.com/f5/loader19.swf?mode=continent&lang=NL&continent=Europe", _
"KNMI.png", "http://www.knmi.nl/", _
"Weather.png", "http://www.oosterhoff.nl/pagina.nl/weer/vakantie/nl.php3", _
"Weather.png", "http://www.oosterhoff.nl/pagina.nl/weer/vakantie/vakantieweer.php3", _
"BuienRadar.png", "http://www.buienradar.nl/home.aspx?r=weer.startpagina.nl&jaar=-3&soort=loop1uur", _
"TeleWeer.png", "http://www.teleweer.nl/freedata/radarbig.gif", _
"WorldSat.png", "http://wind.met.fu-berlin.de/cgi-bin/meteosat.cgi?speed=8&count=24&intervall=30&refresh=10&playmode=Endlos")
arrFavourites_4 = Array ("Onkyo.png", "http://www.avsforum.com/avs-vb/showthread.php?t=487602")
arrFavourites_5 = Array ("Flitsservice.png", "http://flitsservice.nl/", _
"Snelheid.png", "http://www.snelheidscontroles.com/", _
"GoogleMaps.png", "http://www.google.nl/maps" , _
"ANWB.png", "http://www.anwb.nl/published/anwbcms/content/pagina/nieuws/homepage.nl.html")
arrFavourites_6 = Array ("Ftn.png", "http://www.ftn2day.nl/postlist.php?hoofdcat=video&subcat=divx&spots=-1", _
"SABnzbd.png", "http://localhost:4715/sabnzbd/", _
"FirstDown.png", "http://www.firstdown.nl/", _
"Bios.png", "http://www.biosagenda.nl/", _
"BSG.png", "http://www.gateworld.net/galactica/s3/index.shtml")
arrFavourites_7 = Array ("Telegraaf.png", "http://www.telegraaf.nl", _
"NOS.png", "http://www.nos.nl/nos/voorpagina/", _
"Volkskrant.png", "http://www.volkskrant.nl/", _
"NU.png", "http://www.nu.nl/", _
"Elsevier.png", "http://www.elsevier.nl/")
'- Main ------------------------------------------------
SetPropertyValue "Browser.Action", "Waiting"
Sleep 100
Do
Sleep 1
Action = GetPropertyValue ("Browser.Action")
If Action <> "Waiting" Then
If Action <> "" Then
Status = ""
Call Handle_BrowserAction(Action)
If Err.Number <> 0 Then
Status = "Error: " & Err.Description
Err.Clear
SetPropertyValue "Browser.Status", Status
'This property is set here to support a task that handles the Remote PC's Loading PopUp Panel
Sleep 100
Loop
Sub Handle_BrowserAction(Action)
Dim Data
Data = Split(Action, "^")
Select Case Data(0)
Case "OpenPanel" : Call Start_Browser()
Case "ClosePanel": Call Stop_Browser()
Case "Control" : Call Control_Browser(Data(1))
Case "Keyboard" : Call Show_Keyboard()
Case "Favourite" : Call Handle_Favourites(Data(1))
End Select
End Sub
Sub Start_Browser()
Dim Data
Dim LoadingData
Dim EndFlag
Dim DotCount
OpenRemotePanel("Browser Load Pop")
Call Reset_FavCounts(0)
EndFlag = 0
DotCount = 1
Set objIE = CreateObject("InternetExplorer.Application")
Data = GetPropertyValue("Browser.Start Site")
If Data = "" Then
Data = "about:blank"
With objIE
.Navigate(Data)
.Fullscreen = 1
.TheaterMode = 0
.Toolbar = 0
.Menubar = 0
.Statusbar = 1
.Top = 100
.Left = 0
.Width = 1024
.Height = 637 'Is 768 - 100 - Windows Taskbar height
.Visible = 1
Do Until .ReadyState = 4 Or EndFlag = 2
Sleep 200
SetPropertyValue "Browser.Loading", String(DotCount, ".")
If DotCount > 35 Then
DotCount = 0
EndFlag = EndFlag + 1
DotCount = DotCount + 1
Loop
.Document.Focus()
End With
CloseRemotePanel("Browser Load Pop")
SetPropertyValue "Browser.Loading", ""
End Sub
'- Kill current instance + all extra opened instances --
Sub Stop_Browser()
Dim MyShell
'Below is set to kill all iexplorers even if objIE doesn't exist anymore.
'When objIE doesn't exist anymore, this Sub would fail and the Taskkill would not be executed
Set MyShell = CreateObject("WScript.Shell")
objIE.Quit
MyShell.Run "C:\Windows\System32\Taskkill.exe /F /IM iexplore.exe", 0, True
Set MyShell = Nothing
Set objIE = Nothing
End Sub
'- Control Browser options and restore focus -----------
Sub Control_Browser(Data)
Select Case Data
Case "Back" : objIE.GoBack()
Case "Forward": objIE.GoForward()
Case "Refresh": objIE.Refresh()
Case "Stop" : objIE.Stop()
End Select
objIE.document.focus()
End Sub
'- Show Click 'n Typ virtual keyboard ------------------
Sub Show_Keyboard()
Dim MyShell
MyShell.Run "C:\Progra~1\Click-N-Type\Click-N-Type.exe", 0, False
End Sub
'- Handle Favourite buttons ------------------------
Sub Handle_Favourites(Data)
Select Case Data
Case 1: FavCount_1 = Set_Favourite(1, FavCount_1, arrFavourites_1)
Case 2: FavCount_2 = Set_Favourite(2, FavCount_2, arrFavourites_2)
Case 3: FavCount_3 = Set_Favourite(3, FavCount_3, arrFavourites_3)
Case 4: FavCount_4 = Set_Favourite(4, FavCount_4, arrFavourites_4)
Case 5: FavCount_5 = Set_Favourite(5, FavCount_5, arrFavourites_5)
Case 6: FavCount_6 = Set_Favourite(6, FavCount_6, arrFavourites_6)
Case 7: FavCount_7 = Set_Favourite(7, FavCount_7, arrFavourites_7)
End Select
End Sub
'- Set requested Favourite and return the current count-
' - FCount 0, 2, 4 etc = Image - FCount 1, 3, 5 = URL --
Function Set_Favourite(FavImageNr, FavCount, arrFavourites)
Dim URL
Dim FCount
'Store the FavCount in a temp value to save the value of FavCount_x since FavCount is a pointer to FavCount_x
FCount = FavCount
Call Reset_FavCounts(FavImageNr)
FCount = FCount + 2
If FCount > UBound(arrFavourites) Then
FCount = 1
URL = arrFavourites(FCount)
If URL = "" Then
FCount = 1
If URL = "" Then
URL = "about:blank"
SetPropertyValue "Browser.Icon " & FavImageNr, GetPropertyValue("Browser.Picture Path") & arrFavourites(FCount - 1)
objIE.Navigate(URL)
objIE.Document.Focus()
Set_Favourite = FCount
End Function
'- Reset Favourite Counts ------------------------------
Sub Reset_FavCounts(FavImageNr)
Dim nit
Dim Icon(10)
Icon(1) = arrFavourites_1(0)
Icon(2) = arrFavourites_2(0)
Icon(3) = arrFavourites_3(0)
Icon(4) = arrFavourites_4(0)
Icon(5) = arrFavourites_5(0)
Icon(6) = arrFavourites_6(0)
Icon(7) = arrFavourites_7(0)
For nit = 1 To 7
If nit <> FavImageNr Then
SetPropertyValue "Browser.Icon " & nit, GetPropertyValue("Browser.Picture Path") & Icon(nit)
Next
FavCount_1 = -1
FavCount_2 = -1
FavCount_3 = -1
FavCount_4 = -1
FavCount_5 = -1
FavCount_6 = -1
FavCount_7 = -1
End Sub
