The Received Data Property from for example a generic serial device only returns ascii values. It would be a nice feature to also have the ability to return HEX values.
An example would be: ffA0BC3D41
I have a serial device that returns Hex codes and I have to use a script to convert the received data property from ascii to hex.
Received Data Property also in HEX format
http://www.cebotics.com/phpbb2/viewtopic.php?t=855633
This is a link to the scripts section. Download the scripts.zip and look for the PlasmaStatus.vbs script.
Good luck
Good luck
Hi Richard,
Thanks for those.
I have spent all afternoon learning and I have got it working. This has opened a whole new world of possibilities for me now.
I still have one query though...
I have a Hardware remote pumping in Serial comands to a 'Remote Hardware' device, this is the one that I can see that databytes arriving in. I have another Device called 'Remote' that has the script and with property's. Although it works, it seems long winded, but every time I try and remove the Remote Hardware device and re-assign the 'Received Data' it will not function.
Any ideas?
Kind regards,
James.
Thanks for those.
Any ideas?
Kind regards,
James.
I am not sure if I understand your question, but it appears you are describing the process needed by HouseBot to function properly.
You need a hardware device that actually defines the serial port.
Then you need a device that holds the received data property and maybe even other properties that bind to the hardware device.
You also have a script device that defines the script and you can have properties attached to the script device to handle certain stuff or like I do, have an extra NULL device that holds all properties like status etc.
If this is working for you now, you have gotten a long way already and the longer you fiddle with it, the more sense it starts to make.
Hi Richard,
You have answered my question, which I admit could been written a little more legible. The point is that there are three stages, and I was thinking that it should have been two.
Many thanks for your pointers, the only thing I need to figure out now is how to manage data in both directions through a script and apply some other routines.
Kind regards,
James.
Kind regards,
James.
