Unable to find property...
jkish
Post by jkish »
Unable to find property. Device ID = [6], Property ID = [154]
How do I find out what device has ID 6?
What is the best strategy to fix?
Thanks.
If you have MS Access, you can open the database using MS Access. You should be able to see what is what and why something is wrong.
incoronado
Post by incoronado »
I had the exact same problem.
Read this post.
http://www.cebotics.com/phpbb2/viewtopi ... ht=#444801
jkish
Post by jkish »
I'm not sure that this was the same problem.
I opened the database with Access and could see that there was a task referencing a property that didn't exist. It didn't show up in the HB UI, but it was in the database. Not sure how it happened, but I deleted the task and recreated it and that fixed it.
