Whether I'm using it right or not, using an alphanumeric substitution string in a Property Change button crashes my server every time I hit that button in a theme. Here's the situation:
I have an alphanumeric property in a device, the value of which I'd like to "build" with a numeric keypad. So, I defined the buttons of the keypad, and set the Property Change New Value to be itself + the value of the button (ie, %%Cable.NewChannel%% + '1' for the 1 button). When I hit the 1 button on the theme, HB crashes.
Is this something that I can't do (other than via a script/task)?
Thanks.
Substitution string crashing
- Contact:
- Contact:
