Is anyone using HB with the new 5.52 version of winamp? I am having issues with some extra garbage at the beginning of the playlists generated by the playlist manager. I am also not able currently to play manually created playlists either. I figured maybe its not compatible with the latest version. I am also running Vista Ultimate if that matters. Thanks in advance.
A little more info on this: When i set the playlist from the playlist manager and then change the winamp device property "A/V Status" to playing, the device iterates through each song in the playlist and then changes the A/V Status property to stopped but winamp never actually plays any of them.
