Insteon PLM Errors
bjlamarca
Insteon PLM Errors
Post by bjlamarca »
Getting errors releated to the Insteon PLM. Attached logs. Appreciate if you could take a look.
Log.zip
(19.03 KiB) Downloaded 273 times
Re: Insteon PLM Errors
The error is happening because of a data collision. The plugin has asked for a status request. The response from the status request is intermingled with something else (not quite sure what it is). I had a similar issue of data collusion during the plugin development. When I addressed it with SmartLabs/SmartHome, they sent me unit with newer firmware and it resolved the issue.
If you want to address the problem with SmartLabs, hopefully that will resolve this. Another option is that I can downgrade the message to a warning so it won't keep triggering an error. The plugin does detect the error (obviously) and resends the status request (which returned good the second time with no collision).
bjlamarca
Post by bjlamarca »
I would appreciate if you could downgrade the message to a warning. Everything is working fine and I just don't have the time to deal with SmartLabs right now.
