Property readonly
DsA
Property readonly
Post by DsA »
How to prohibit editing of property by the user in Device Plugin?
Re: Property readonly
If you are creating your own Device using the SDK, set the 'eIOType ioType' parameter of the 'pHB_RegisterDeviceProperty' call to 'ioInputOnly'.
DsA
Post by DsA »
Thanks. Still a question. How to set restriction of entered values, for example from 0 to 100?
If you have derived a class from the CHardwareInterface class, you just need to call
CHardwareInstance::SetPropertyLimits( const char* szPropertyName, int nLowLimit, int nHighLimit )
or pHB_SetPropertyLimits if not using CHardwareInterface. Call it right after you register the Property (RegisterHardwareModuleProperty).
DsA
Post by DsA »
It in Hardware Interface Plugin. I have not found the same function in Device Plugin?
DsA wrote:It in Hardware Interface Plugin. I have not found the same function in Device Plugin?
You're right. Sorry I was confused.
You can't restrict what a user will enter for a Property Value. The best you can do is to offer suggestions by associating Property Values to a Property by calling pHB_CreateDevicePropertyValue() when registering a new Property for the first time.
You can still generate an error or just refuse to change the Device Property in the plugin if the user tries to change the Property to an invalid value.
DsA
Post by DsA »
I create properties calling pHB_CreateDevicePropertyValue () but how thus to set values of properties? It is possible a code example?
Here's a snippet from the ::RegisterProperties() method of a Device plugin.
// First attempt to register the Property (wizard version of registration that has prompt)
if (!m_CallBackInfo.pHB_RegisterDevicePropertyUsingWizard( m_CallBackInfo.m_hModuleHandle,
                                                           nDeviceNumber,
                                                           "Insteon Group",
                                                           "Group", FALSE,
                                                           "1",
                                                           ioInputAndOutput,
                                                           TRUE,
                                                           TRUE,
                                                           FALSE,
                                                           FALSE,
                                                           "Enter the group number" ))
   // The registration failed.  This is probably because this is the first time the property is being registered.
   // Attempt to create the new "Insteon Group" Property.
   if (!m_CallBackInfo.pHB_CreateDeviceProperty( "Insteon Group", "Group", ptNumeric ))
      return( FALSE );
   // The Property created successfully.  We can optionally add values to the Property.
   // This example creates numeric values from 1 to 256
   m_CallBackInfo.pHB_CreateDevicePropertyValue( "Insteon Group", "[1 - 256]" );
   // If not adding a sequential numeric range like above, call pHB_CreateDevicePropertyValue() for
   // each value to be added to the Property.
//   m_CallBackInfo.pHB_CreateDevicePropertyValue( "Insteon Group", "1" );
//   m_CallBackInfo.pHB_CreateDevicePropertyValue( "Insteon Group", "2" );
//   m_CallBackInfo.pHB_CreateDevicePropertyValue( "Insteon Group", "3" );
   // Now that the Property has been created, we can try and register it again (same call as at the top)
                                                              nDeviceNumber,
                                                              "Insteon Group",
                                                              "Group",
                                                              FALSE,
                                                              "1",
                                                              ioInputAndOutput,
                                                              TRUE,
                                                              TRUE,
                                                              FALSE,
                                                              FALSE,
      return( FALSE );
DsA
Post by DsA »
I thank, all works =)
vc1234
Post by vc1234 »
I've attached a dll with the read-only Temperature property (ioInputOnly). I believe the device has to be recreated for ioInputOnly (should it not be rather called ioOutputOnly ?) to take effect.
TemperPlugin.rar
(13.24 KiB) Downloaded 1917 times
EdInNY
Post by EdInNY »
Just an FYI;
The comments in DeviceAPI.h say "ioType - Not currently used, but can/should be set correctly."
- Ed
Thanks. I'll update the comments, since that argument is now used.
