Your error states it cannot find the specified file. Should be easy. Did you get the 8 out of the filename. If your name is OK and your script device points to the right file, you should post the script so I can see if the error is somehow occuring in your script itself.
Do you have other scripts running that do work?
Status update - scripting it away
