Device plugin for m-cubed T-balancer help needed.
raptor_demon
Post by raptor_demon »
I was going through my computer parts the other day and found i have a T-balancer board.
Basically this thing is a temperature and fan controller for a pc.
http://www.t-balancer.com/english/index.htm
I was thinking i could probably interface to this and use it to get room tempratures.
Could someone point me in the right direction as how to start this plugin?
thanks
raptor_demon
Re: Device plugin for m-cubed T-balancer help needed.
Could someone sugest how i might strat writing a plugin?
I have never tried todo this before.
If you go to the 'download' section of the main HouseBot site, you will find the C/C++ SDKs for creating devices and hardware interfaces. If you are able to write C/C++ code, there should be enough there to get you started.
There is also a .net device SDK floating around somewhere that you may be able to use.
To fit perfectly in the architecture, you would create a hardware interface plugin that communicates with the board, and then 1 or more device plugins that communicate with the hardware interface.
If you get started, I can answer more specific questions as they come up.
