Hi Scott,
I have read the other threads about HouseBot crashes and dumps and I figured they don't really match my problem, so I decided to start a new thread.
HouseBot has been dumping on me completely randomly for the past several weeks. Here are the time and dates:
HouseBotServer-10-01-2003.DMP 2,302 10/1/2003 7:14:36 PM
HouseBotServer-10-02-2003.DMP 879 10/2/2003 9:39:18 PM
HouseBotServer-10-03-2003.DMP 1,884 10/3/2003 5:45:08 PM
HouseBotServer-10-07-2003.DMP 1,073 10/7/2003 8:22:14 PM
HouseBotServer-10-17-2003.DMP 4,328 10/17/2003 6:05:50 AM
HouseBotServer-10-25-2003.DMP 1,364 10/25/2003 10:00:30 PM
HouseBotServer-11-01-2003.DMP 1,955 11/1/2003 11:22:54 PM
HouseBotServer-11-07-2003.DMP 1,664 11/7/2003 10:21:46 PM
HouseBotServer-11-11-2003.DMP 1,768 11/11/2003 8:48:24 PM
HouseBotServer-11-13-2003.DMP 2,043 11/13/2003 9:30:32 PM
HouseBotServer-11-14-2003.DMP 2,069 11/14/2003 9:30:56 PM
Below is the latest dump file, which happened a couple of hours ago:
====== Begin Dump - Friday, November 14, 2003 21:30:55 ======
Server Version = 1.51
Thread Type = Device Thread [Living Room Left Side Lamp]
Thread ID = 594
Fault address: 77C43283 01:00032283 C:\WINDOWS\system32\msvcrt.dll
Registers:
EAX:06920DC4
EBX:00000001
ECX:3FFC8371
EDX:00000003
ESI:069FFFFD
EDI:069FFFFC
CS:EIP:001B:77C43283
SS:ESP076FFB80 EBP:076FFB88
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010202
Fault address: 004C83E3 01:000C73E3 C:\Program Files\HouseBot\HouseBotServer.exe
Registers:
EAX:24069B4B
EBX:069C8108
ECX:069C8108
EDX:06F419A8
ESI:069155C0
EDI:06F40690
CS:EIP:001B:004C83E3
SS:ESP06CFF23C EBP:06FF4528
Flags:00010246
Call stack:
Address Frame
004C83E3 06FF4528 0001:000C73E3 C:\Program Files\HouseBot\HouseBotServer.exe
069CE530 00531688 0000:00000000
004C9B20 004C9A90 0001:000C8B20 C:\Program Files\HouseBot\HouseBotServer.exe
====== End Dump ======
Thread Type = Device Thread [System Time]
Thread ID = 42C
Registers:
EAX:24069B4B
EBX:069C8108
ECX:069C8108
EDX:06F419A8
ESI:069155C0
EDI:06F40690
SS:ESP074FF810 EBP:06FE3138
Flags:00010246
Call stack:
Address Frame
004C83E3 06FE3138 0001:000C73E3 C:\Program Files\HouseBot\HouseBotServer.exe
069C1248 0053169C 0000:00000000
004CA560 004C9D80 0001:000C9560 C:\Program Files\HouseBot\HouseBotServer.exe
FFFFFF58 E8F18B56 0000:00000000
I am running HouseBot v1.51, Windows XP with SP2, Dual P3-866MHz CPU, 640 MB RAM, and I don't think this matters but I'm running RAID 1 (mirror) on two 30GB hard drives for redundancy.
Any ideas??
- John
HouseBot dumping completely randomly
Trust is good but control is better...
Hi Scott,
Well I upgraded to v1.60. But now I can't even create a new device !! As soon as I click Create New Device, HouseBot just closes. I tried asigning HouseBotServer.exe to one processor as well, but it still crashes.
Here is the dump after trying to create a new device:
====== Begin Dump - Saturday, November 15, 2003 16:30:11 ======
Server Version = 1.60
Thread Type = Main UI Thread
Thread ID = 238
Fault address: 004B6AC0 01:000B5AC0 C:\Program Files\HouseBot\HouseBotServer.exe
Registers:
EAX:00000000
EBX:00AEAD80
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
CS:EIP:001B:004B6AC0
SS:ESP0012E8A0 EBP:0012F8AC
Flags:00010246
Call stack:
Address Frame
004B6AC0 0012F8AC CxImage::`copy constructor closure'+B5050
====== Begin Dump - Saturday, November 15, 2003 16:30:35 ======
Thread ID = F8
Registers:
EAX:00000000
EBX:00AEAD80
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
SS:ESP0012F220 EBP:0012F8AC
Flags:00010246
Call stack:
Address Frame
====== Begin Dump - Saturday, November 15, 2003 16:33:13 ======
Thread ID = 6CC
Registers:
EAX:00000000
EBX:00AEAD88
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
Flags:00010246
Call stack:
Address Frame
====== Begin Dump - Saturday, November 15, 2003 16:33:34 ======
Thread ID = 7B8
Registers:
EAX:00000000
EBX:00AEAD88
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
Flags:00010246
Call stack:
Address Frame
I wonder if it's Windows XP or something. Do you have any other ideas? Should I go back to v1.51 ??
- John
Thread ID = 238
Registers:
EAX:00000000
EBX:00AEAD80
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
Flags:00010246
Call stack:
Address Frame
Thread ID = F8
Registers:
EAX:00000000
EBX:00AEAD80
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
Flags:00010246
Call stack:
Address Frame
Thread ID = 6CC
Registers:
EAX:00000000
EBX:00AEAD88
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
Flags:00010246
Call stack:
Address Frame
Thread ID = 7B8
Registers:
EAX:00000000
EBX:00AEAD88
ECX:00000000
EDX:001548D8
ESI:0012F8AC
EDI:0012F90C
Flags:00010246
Call stack:
Address Frame
- John
John,
It's crashing in a different place now. After you create the Device, are you clicking on a Theme or does it crash immediately after creating the Device?
Also, are you using a CM11a?
Was there something that you changed in the configuration before this started happening (if you can remember)?
I'd like to try and reproduce the problem here. Could you send my your HBData.mdb file (found in \HouseBot\Config) for starters? Maybe there's an anomalous configuration setting somewhere. Send it to [email protected].
If you want to reinstall version 1.5x, you should be able to install over the 1.6, but you will first need to delete the HouseBotServer.exe file.
John,
If you want to reinstall an older version, I would suggest you install 1.52 instead of 1.51. Here's a link 1.52.
Hi Scott,
It crashes right after I click on Create new Device. Or right click and select Create New Device. It doesn't even go into the device creation window. It just crashes. I am doing nothing to the themes either.
I am using the CM11A, and I have not changed the configuration at all for quite some time.
Strange thing is, I installed 1.60 on my laptop (Win98), then copied everything onto there, and I created a device there with no problems. Then I copied back to my PC and the device was there. I just can't seem to add a device on this PC.
So it appears that maybe there's something on this PC that HouseBot doesn't like. Not sure if there are any other problems, but this is all I have found so far. I will email you the mdb file right now.
Thanks Scott.
- John
Thanks Scott.
- John
John,
I think I've fixed the 1.60 crash you were seeing. The fix will be in the 1.61 update that I plan on releasing next week. If you're interested in trying it before that, let me know and I'll pass a beta copy along to you.
If you installed version 1.52, I'm interested in knowing whether it fixed your original problem. There was fix in 1.52 that solved something very similar to what you were seeing.
Hi Scott,
I just went ahead and installed 1.52 just to see, and yes it did solve the problem. I created a device successfully without any problems.
I will wait for you to release 1.61 next week, unless you think it might be helpful in your development to install the beta now. If not, I will continue to run 1.52 until the release.
Thanks a bunch,
- John
Thanks a bunch,
- John
Hi Scott,
I guess I should have started two separate threads since there are really two issues here. So I'd like to clarify.
In my response, version 1.52 seems to have resolved the "Create New Device" crash problem, but I am not sure whether it has resolved the random dump problem.
By this, did you mean the random crashing, or the crash due to "Create New Device"? Or both?
Sorry about the confusion.
- John
I assume by "original problem" you mean the random crash problem. Sometimes it takes a few days to dump. So I guess I'll let you know.If you installed version 1.52, I'm interested in knowing whether it fixed your original problem. There was fix in 1.52 that solved something very similar to what you were seeing.
- John
John,
By Original Problem I meant the random crashes. In looking at your original dump files I saw a similar problem that was a fixed in 1.52. So hopefully you will be ok.
I really doubt you will see the Create New Device problem with 1.52. In 1.60, I enhanced/reworked that dialog. I can't say that I completely understand why you are seeing the problem in 1.60, but I've added some defensive code so at least it won't crash. I'll be interested to hear how it works for you.
Hi Scott,
I have been running HouseBot 1.61 now for about a week and no crashes
Only thing is, I get some errors in the error log, but it doesn't seem to affect the operation of HouseBot or any of its tasks:
-MR26A has recieved an invalid unit code(0xb0) etc..
-Error reading COM port ....
-Due to an error device [xxxxx] did not change state ...(but it actually did)
etc.....
So I'm not sure what that means. Should I just ignore these entries since they don't seem to really affect anything?
- John
etc.....
- John
John,
It's good to hear that 1.61 is working better for you.
Sometimes I'm overly conservative and probably log too many things as errors. If the MR26 receives some garbage, or a trashed signal, it's possible that you may see some anomalous errors. It's also possible that there's a bug in the Interface that has not yet been uncovered.
If all of the errors are related, it might point to a single problem so you can ignore everything except the initial error message.
Feel free to send me the error logs, if you want.
Hi Scott,
First off, Merry Christmas and Happy New Year. All the best for you and your family in the new year, and thanks for all the hard work.
Sorry it took so long to send the errors, but I realized I wasn't logging, and then before you know it the holiday season was upon us, so I kinda forgot
Well here are a few examples of the errors I'm getting. But like I said, they don't seem to be affecting HouseBot's functionality.
Dec 30 2003,07:50:09PM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x80]"
Dec 31 2003,10:07:13AM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x81]"
Dec 31 2003,11:39:12AM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x41]"
Dec 31 2003,02:13:21PM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x80]"
Dec 31 2003,07:10:41PM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x31]"
Dec 31 2003,08:55:12PM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0xc6]"
Jan 01 2004,12:32:12AM,X10 CM11A Module,Error,"Error reading COM port. Error = Insufficient data in read buffer"
Jan 01 2004,12:32:13AM,Property:Power State,Error,"Due to an error, Device [Front Yard Camera] Property [Power State] DID NOT change."
Jan 01 2004,12:32:23AM,X10 CM11A Module,Error,"Error reading COM port. Error = Insufficient data in read buffer"
Jan 01 2004,12:32:24AM,Property:Power State,Error,"Due to an error, Device [Front Yard Camera] Property [Power State] DID NOT change."
Jan 01 2004,12:32:35AM,X10 CM11A Module,Error,"Error reading COM port. Error = Insufficient data in read buffer"
Jan 01 2004,12:32:35AM,Property:Power State,Error,"Due to an error, Device [Front Outside Spot Light] Property [Power State] DID NOT change."
Jan 01 2004,12:32:46AM,X10 CM11A Module,Error,"Error reading COM port. Error = Insufficient data in read buffer"
Jan 01 2004,12:32:46AM,Property:Power State,Error,"Due to an error, Device [Front Outside Lights] Property [Power State] DID NOT change."
Jan 01 2004,02:25:24AM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x82]"
Jan 01 2004,06:57:49AM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x1]"
Jan 01 2004,09:44:38AM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x90]"
Jan 01 2004,09:47:01AM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0xc4]"
Jan 01 2004,12:12:53PM,X10 MR26A Module,Error,"MR26a has received an invalid unitcode value [0x2]"
The "invalid unit codes" are pretty self-explanatory. But for the other ones, even though the errors say that the "power state did not change", it did. So I'm not too concerned about it, but it would be nice to get "real" errors in the error logs. Maybe these are real errors I don't know...It does occur occasionally for other devices as well.
I'm still running v1.61 and it has been rock solid let me tell you !!
- John
- John
John,
Thanks for the info and I'm glad that 1.61 is stable for you. I recall that when I used to use the MR26, I was seeing these types of errors as well. I upgraded to the W800 and didn't receive any errors.
If you are receiving the error AND the device state is still changing, it's probably because the MR26 received a good signal and a bad signal right after one another. The MR26 repeatedly reports the same information.
It may very well be that the sensitivity of the MR26 is such that I need to buffer the error message and not send it if a valid command is received right after it.
Since it is functionally working for you, I'm going to add it low on my list for right now. I'll get to it, but I've just got some bigger items ahead of it.
