Error CM11a
jacco van der Ven
Error CM11a
Post by jacco van der Ven »
What a great progam is this, Thanks.
It was working fine no I have an error on the CM11.
It says the following:
Error. The buffer size [90] returned from the CM11a is larger then maximum expected[11]
Can somebody help me with this.
Best regards,
Jacco, The Netherlands
Jacco,
Do you see this problem all the time, or just the one time?
If you can run a trace for me, I can look into it in more detail. To generate a trace file:
  1. From the HouseBot main menu, select 'Settings/Tracing...'.
  2. Press the 'Advanced' button.
  3. Select the name of the CM11a interface in the list (it will be prefixed with an asterisk).
  4. Select the 'File' checkbox and enter a file name in the edit field below (file name only).
  5. Press OK to dismiss all dialogs.
  6. Try and use the interface again. This should generate data in the log file.
  7. Turn the tracing off by returning to the 'Advanced' tracing dialog and removing the check by the 'File' option.
  8. Send the trace file to me at '[email protected]'. The file can be found in the HouseBot\Logs directory.
Send the trace file to [email protected].
