Can't get HB to control WinAmp reliably
kbosscawen
Post by kbosscawen »
I've got to be missing something - I can't get the WinAmp device in HB to reliably control WinAmp 3 (with the 2 plugin). I know HB is communicating with WinAmp (when the Play Source is changed, WinAmp loads [but doesn't play], EQ on/off works,...) but I can't seem to get WinAmp to actually play when I change the Play Source or A/V Status properties in HB. Anyone have any tips?
Thanks much!
I know the setup of the Properties for the Plugin is kinda picky. Make sure you go over the online help to make sure it is setup correctly. Also, you might want to make sure it works with WinAmp 2.x also.
If you're still interested in the WinAmp configuration, see this post.
