Meedio HouseBot SDKs
Edit: The Meedio HouseBot SDKs have been moved to the Meedio Add-Ins Directory.
- Advanced Member
- Contact:
This is not a complete list but should be close
1) Any X10 device via firecracker(soso), CM11A, Powerlinc USB hardware
2) Any IR device that uses a carrier freq between 35 - 50 Mh via the USB-UIRT or Global Cache GC-100 or Ocelot hardware
3) Sony mega-players via Ocelot (CDJ support)
4) Any device that uses RS-232 communications via the PC serial port or the Global Cache GC-100 serial port
5) Relay via the Global Cache relay port
6) Caller ID and modem status via modem/phone plugin
7) Interface support for Girder
Interface to Winamp
9) Plugin for the xmltv software for TV listings
10) An email sender
11) Ability to launch an external program
12) An active x control for use to interface web pages
13) An external command interface to facilitate control from external applications
14) A VB Scripting capability to run VB Scripts within HouseBot
15) There are some other user developed plugins - see postings in this section
10) An email sender
The "near future" has come and gone.....
Any ETA on the VB SDK?
Would be really nice with either that or the housebot/meedio plugin
Cheers
/p
Cheers
/p
HTPC Specs:
Motherboard: EPIA M10000 1Ghz
512MB 400Mhz DDR RAM
120GB + 200GB HDD
boinc2mee - View your Seti@Home stats through Meedio
120GB + 200GB HDD
Please note, the Meedio HouseBot Interface SDK and Device SDK have been moved to the Meedio Add-Ins Directory.
acheslow wrote:Please note, the Meedio HouseBot Interface SDK and Device SDK have been moved to the Meedio Add-Ins Directory.
sure would like to read more into this.
osetivo wrote:sure would like to read more into this.acheslow wrote:Please note, the Meedio HouseBot Interface SDK and Device SDK have been moved to the Meedio Add-Ins Directory.
