Learing IR Problem
Circe640
Learing IR Problem
Post by Circe640 »
I have been trying to learn the IR from the Outlaw 950 remote. It seems to use a very short burst. I get to 36% and then the IR from the remote control stops so I never get a code learned. :cry:
I downloaded all three ccf files from remotecentral and have managed to extract most of the needed codes but 1, the code for V3/Cable. None of the three CCF files had it :(
What is the trick to learning very short code bursts?
The answer is going to be hardware specific, as HouseBot isn't really too involved in the learning process. What hardware are you using?
Circe640
Post by Circe640 »
USB - UIRT I learn using this and then import from the USB-UIRT to the GC-1000 --- this works vey well so far!
The only remotes that have caused problems trying to learn them have been the Pioneer DV563 and the Outlaw 950. I was able to get all the codes for the 563 via Pronto files and have 99% for the Outlaw the same way Its the last 1% which happens to be one of the input selections V3/Cable that is not in any of the Pronto files I have found. I also haven't been able to learn the Outlaw remote codes on my Pronto either!
