Caller ID?
switzch
Caller ID?
Post by switzch »
Can Meedio Housebot display caller ID info? Also, if I have meedio running on the same computer as housebot, with the callerid plugin, will there be problems with sharing the modem?
HouseBot has a plugin that will grab the caller ID info from a caller ID modem. However, since modems/com ports don't share very well, I don't think you can share the same modem between HouseBot and Essentials.
When the integration plugins are complete, you should be able to connect to the modem with either Essentials or HouseBot and share the data with the other system.
