How do I feed winamp plugin a playlist?
Zei
Post by Zei »
Should I be able to feed winamp plugin field (Currenty Active Playlist, Playlist1,2,3,4 or some else field) a playlist, SO that plugin reads all the mp3s to its list, so that those are browsable ie. =+1 =-1
And in which format this playlist should be. I have tried .m3u and .pls. Both play as "play source" but are not browsable.
Yes you can. The setup's a bit hard to explain in a post.
Check out the configuration sample for WinAmp in this post. Also, the online help for the WinAmp plugin goes into some details.
