Direct X10 command "Status Request"
alibaba
Post by alibaba »
How can I use the direct x10 command "Status Request" within housebot?
Does it update the properties of the device with their current state of the device?
Which devices are supporting this feature?
-Alibaba-
Only certain X10 devices support Status Request. Many times the devices that actually support the feature are considered 2-way devices and will send their status when their state changes. Any changes, whether received from a status request or as a response from a 2-way switch, will cause the Properties of the HouseBot Device to be updated.
alibaba
Post by alibaba »
This behaviour is well known to me.
But I have a certain time during the night where my computer is turned off. After the reboot and the start of housebot, it would be good if I could send a status request, to get the correct state of the device in housebot.
If the state was changed during the power-down period.
So how do I send this status request from housebot?
Each HouseBot X10 Device has a Direct X10 Command Property. If you change that Property to Status Request, it will issue the command.
