Unable to find Mode ID [25]. Mode does not exist
derek
Post by derek »
I receive this message in Housebot status line.
There is no mode ID 25 in any of the database tables.
Any idea where it is coming from?
What do I search for in a theme XML file to find any reference to mode ID 25.
The message dosen't cause any problems with Housebot operations but I am sick of looking at it.
Help would be appreciated.
Thanks.
It is probably coming from a Software Remote. Theme XML files don't have referential integrity with the main HB database. So if you delete something (like a Mode) from HouseBot and it is still referenced in the Theme, it gets orphaned.
I would suggest looking through whatever Theme(s) you are using in any active Software Remotes for a reference to the Mode. You may need to look through the Theme XML file manually to find and delete it. Look for a "Button" element that contains M_ID="25" as an attribute and just delete the line.
