Vb Scripts for x10 control
MagicalDreams
Post by MagicalDreams »
Hi I have down loaded the meedio house bot and have it working with my lights through a CM11 interface. I have tried the sample vb to raise a light from dim. that all works fine. My problem is that I have limited vb knowledge can anyone supply me with some script samples that I can modify. I can do some modification but have not managed to Wright my own as yet. if this is not possible can someone supply the codes that I can use. any help would be gratefully received
If you look at the online help for the Script Device, it will give the HouseBot specific VB Script calls that you can use. It also contains a link to the Microsoft web site that gives more detail on general VB Script programming and the calls you can use.
