Anyone out there managed to do this. I have setup a task (with Scottbots help) that will control my projection screen.
I can only see a way of controling DEVICES thru the link in Essentials and not TASKS.
So my other option is to program a command so when i press the ON button on my remote (universal Sunwave SRC-3000) it will detect the IR signal and run the TASK.
I currently use a IR program called Sconi that controls all my Essential movements by linking the IR code to a hot key.
ie the select button for Essentials is Enter. hot key for enter is CTR+F in meedio.
Therefore i program Sconi so when it receives IR code BF3000 that code is linked to meedio program and CTR+F command, and it will = the select button ie enter, in meedio menu.
Anyone know if i can do this in HB or Essentials?
Does any one know how to run a task by IR Remote Control?
- HouseBot Special Member
- Contact:
I don't use Essentials. Here's how to do it in HB:
- Get an IR device that HB can work with (like the great USB-UIRT)
- Install it
- Create an IR receiver device
- Teach HB some IR codes - make sure to check the 'code will be send and received' box
- Create a new 'automatic' task (select 'when conditions are met')
- Type in some 'if' sentences like:
* if 'IR Receiver.IR Code Number Received' is equal '123' Then
* Execute task 'task 1'
That's all
- Install it
That's all
hmmm thanks for your reply, but i dont want to buy anything else, my sconi usb plug in works a treat for all my remote needs to control Meedio. up down left right, enter, pause, play, etc etc you get it....
as i want to be able to able to drop my screen in essentials when i press the button for say Movies in essentials and when i press the play button it turns the lights off, i want it all to run together and it seems a bit "bitty" at the mo.
i want to use the same device, so i guess ill have to see if they can support sconi to link with housebot too.
i actually thought this would be easy and id be pulling out my credit card for HB, but its a lot more hard work than i thought.
